Problem with Megaupload Plugin - Not Supported URL [SOLVED]
December 20, 2009 12:04AM
The megaupload plugin cannot download the file at this page alerting that the URL is not supported...
FRD version: 0.83u1
Plugin Version: 1.9.3
app.log is attached to the post... and an image of the error is attached either...
Best Regards,
45678912
Edited 1 time(s). Last edit at 12/20/2009 01:01AM by 45678912.
open | download - app.log (1.2 KB)
open | download - Image of the error.png (268.5 KB)
Re: Problem with Megaupload Plugin - Not Supported URL
December 20, 2009 12:12AM
Delete MU plugin from plugins directory and downgrade to 1.92 by checking for new updates of the plugin.
December 20, 2009 12:56AM
thanks...
I'll try it...
December 20, 2009 01:01AM
thanks... it works perfectly....grinning smiley
Re: Problem with Megaupload Plugin - Not Supported URL [SOLVED]
December 20, 2009 10:34AM
OK so adding [^v][^i][^d][^e][^o] to urlRegex wan't a good idea after all. tongue sticking out smiley
I was wondering if we could just do this? \\?[df]=
All supported links have ?d=... or ?f=... in them.
December 24, 2009 02:08AM
this link wasnt working also and after downgrading works perfect !
thanks \@1@/
