filebox issue with required information
Posted by hklkf200553
January 11, 2010 02:07PM
1. Check that you are using the latest version of the plugin
checked update
* your FRD version
0.83u1
* your plugin version (please see Options -> Preferences -> Plugins - Settings),
filebox.com ,version 0.5.1
* describe problematic behaviour,
no wait time value between "and '<' was found
* provide download links you have problem with.
[www.filebox.com]
(actually all filebox link are not work )
maybe filebox has change the layout ?
Re: filebox issue with required information
January 11, 2010 02:43PM
That link, and other links too, work just fine for me.
Seems like the plugin has no handling code for the "maximum downloads per day" error... Are you sure you haven't reached that limit?
January 11, 2010 03:18PM
i haven't download for a week =p=
none was working @.@
i try it later
January 12, 2010 03:36AM
still give the same result /.\
January 12, 2010 09:26AM
Same problem here.. It seemed there do no free download access to the file . Only Premium and Registered left. So, Is there anywhere I can input my username/passwd pair to config the plugin?
January 12, 2010 09:27AM
premium is not supported
January 13, 2010 04:54AM
i access it through browser : chrome , ie , FF
free download is decline , only provide free user login or premium
is there possible to add setting about login with free user account ?
January 13, 2010 04:55PM
> free user account ?
Nope, that isn't supported either.
