Problems with Mediafire
March 02, 2010 08:06AM
Since yesterday, when I try to download a mediafire link, I received this message:
PROBLEM - No string between 'var mL=" and ";' was found
But the link works manually.
I'm using the mediafire plugin 1.1.3.
Any solution???? Thanks!
Re: Problems with Mediafire
March 02, 2010 08:07AM
We need some test links. Thanks.
March 02, 2010 08:30AM
March 02, 2010 09:29AM
I also have the same problem .sad smiley
When i try to download from my mediafire links , all i get is "error" . sad smiley
Hope you can fix it . Thanks .
March 02, 2010 03:25PM
Found this error when starting download from MediaFire:
ERROR - No string between 'var mL=" and ";' was found
FRD version 0.83u1, plugin version 1.1.3
Sample link: mediafire_link
Please repair it eye rolling smiley
Thanks in advance.
March 03, 2010 03:15AM
I have same problem,
I also tried it with several MediaFire's download link and got the same error
"No string between 'var mL=" and ";' was found"
please help
March 03, 2010 04:25AM
I also have same problem. Please check and fix it.
Thank you very much!
March 03, 2010 07:08AM
Any idea from Admin???
March 03, 2010 07:12AM
Be patient.
March 03, 2010 04:59PM
Does this problem will be solved today yet?
ps: I do not speak English so my English is bad.
Sorry, you can't reply to this topic. It has been closed.
