FRD not working for certain Rapidshare links
April 05, 2010 08:03PM
Hi to all,
can someone tell me why this link isn't working?
I have it with a lot more of those links so this is just an example.
And is there a way to recognize not working links?
Downloading the same link as a free user gave no problem at all
(except for the 90 seconds waiting time sad smiley.
[rapidshare.com]
See the pic for the notification I get.
Thanks in advance.
Regards,
Uitkijker (Marcel).
I tried to add an answer but that failed.
(Phorum Database Error
Sorry, a Phorum database error occurred.
Please try again later!)
I deleted FRD, cleaned my register and reinstalled FRD, like i tried before.
It works fine now. Sorry for this late answer but I have been away for a long time.
Thx everybody for helping me out. smiling smiley
uitkijker.
Edited 6 time(s). Last edit at 04/20/2010 02:26AM by uitkijker.
open | download - notsupported.jpg (46 KB)
Re: FRD not working for certain Rapidshare links
April 06, 2010 04:42AM
It's your own fault for downloading such disgusting videos. thumbs up smiley
OK just kidding... But it should definitely be supported. First, make sure your RapidShare plugin is enabled in Options > Preferences > Plugins.
April 06, 2010 08:59AM
I hope you liked the vid grinning smiley, otherwise you couldn't tell it was disgusting winking smiley.
I have checked that and it should be working because some other rapidshare links do work fine.
In the past I have "managed" to get 8 downloads on a row easily and that is why I like to use FRD.
Somehowe the number of not working links seems to increase.
I have removed FRD, cleaned my register with two programs, rebooted my PC and used a new clean version of FRD.
It didn't worked out.
Regards,
April 06, 2010 09:02AM
nt: check regexp in plugin.xml
April 06, 2010 09:25AM
I did, and it should work. confused smiley
http  ://                       rapidshare .com/files/33853641111111/Lotta_knullar_i_skogen.wmv
https?://((www\.)|(rs[0-9]+\.))?rapidshare\.com/files/[0-9]+        /.*
April 06, 2010 09:26AM
I see a test link without second slash
   rapidshare.com/files/33853641...r_i_skogen.wmv
Edited 1 time(s). Last edit at 04/06/2010 09:26AM by Vity.
April 06, 2010 09:27AM
Yes, but check the screenshot.
April 06, 2010 09:28AM
Nt: does happen the same thing to you?
April 06, 2010 09:30AM
I tried the link in the screenshot, and no, it does not happen for me.
April 06, 2010 09:32AM
So his RS plugin was not properly loaded. Probably invalid FRD path or disabled plugin or something like that.
Edited 1 time(s). Last edit at 04/06/2010 09:33AM by Vity.
