FileFactory plugin problem
Posted by deep_dep
May 18, 2010 06:22PM
Well as the title says I have a problem with downloading from filefactory.com.
I use FRD 0.83u1 version.
The plugin i have is FileFactory.com 1.1.7
Generally I paste the links, than FDR chekcs them and as soon as it tries to download there is an error messegae saying "The tag 'Download with File Factory Basic' was not found!" and the download crashes.
[www.filefactory.com] - and example link i tried to download.
Here is a link to upload app.log file-[www.filefront.com] (could't attach it to the post for some reason).
The links are fine, cause I ma able to download files via my web browser, to it is surely an FDR issue.
Any ideas or solutions to the problem?
Thanks in advance
Edited 1 time(s). Last edit at 05/18/2010 06:32PM by deep_dep.
Re: FileFactory plugin problem
May 18, 2010 06:36PM
Thanks for reporting.
Old links work fine, but newer ones seem to have a new piece of encryption JavaScript. I'm not sure if I'm able to fix this.
May 27, 2010 05:50PM
Plugin v1.1.8 should work now.
May 28, 2010 07:10AM
thumbs up smiley Handclaps to ntoskrnl thumbs up smiley
It works fine again!
May 30, 2010 01:43PM
Ha! Thanks alot :D
