Hotfile CAPTCHA problem
Posted by TiaSorella
July 10, 2010 01:15PM
just downloadded FRD 0.83 (even if here the version is wrong [wordrider.net])
Hotfile plugin: 0.6.18 (the last one)
problem:
I try to download this HF directory
When countdown finish i must read capcha.
If I press cancel ==> ERROR: Server requires correct CAPTCHA input from user
Are RE-CAPTCHA a problem? when can you fix it?
thanks a lot ;)
Re: Hotfile CAPTCHA problem
July 10, 2010 01:25PM
The error you get pretty much says it all.
July 10, 2010 01:38PM
what? sorry but i don't understand =)
July 10, 2010 01:40PM
The error says: Server requires correct CAPTCHA input from user.
Is there some word in that sentence you don't understand?
July 10, 2010 02:17PM
but FRD hasn't got a OCR system?
July 10, 2010 02:24PM
Yes, a very simple one. Unfortunately ReCaptcha is impossible to recognize using computers due to its design. You can find more about it here:
[recaptcha.net]
[en.wikipedia.org]
