Multiupload.com doesn't work
residentlion
residentlion
August 22, 2010 06:22PM
PLUGIN:
Multiupload.com
- FRD version:
0.83u1 build #522
- Plugin version:
1.0.2
- Behaviour:
ERROR: File name not found
- Links: [
www.multiupload.com
www.multiupload.com
www.multiupload.com
www.multiupload.com
ntoskrnl
Re: Multiupload.com doesn't work
August 22, 2010 07:30PM
Admin
You can remove "MU_" and it will work fine.
Anyway, I added support for such links in the plugin. It requires FreeRapid v0.85 though (the plugin now adds the correct link based on plugin priorities), you can download the alpha here: [
wordrider.net
residentlion
August 22, 2010 08:10PM
Thanks for the quick answer
I will remove "MU_" for now, to finish a few suspended links.
then i will take a look at the latest alpha v0.85
