plugin for rapidshare doesn't work?
Posted by MyUser
September 27, 2010 02:31PM
Hi guys,
old format:
[rapidshare.com]
new format:
[rapidshare.com]|334|419573452|abcdefg.rar|137018
That's why the rapidshare-plugin doesn't work, does it!?
Greets
Re: plugin for rapidshare doesn't work?
September 27, 2010 02:42PM
RS changed completely, please wait patiently until we fix the issue. smiling smiley
September 27, 2010 04:24PM
OK, the issue should be fixed in plugin v1.1.0.
September 27, 2010 04:57PM
Great job! Thank You ! Rapidshare works again !!!
smileys with beer
September 27, 2010 05:20PM
@ntoskrnl
OK! After downloading one Rapidfile it says:
Wait 13h:17min ?
maybe a misinterpretation. It should be 13m:17s ?
FR:0.83u1
Rapidshare: 1.1.0
September 27, 2010 05:49PM
Oops, it was a small mistake on my end. Please try plugin v1.1.1.
September 27, 2010 06:00PM
After my next download I'll tell you the result ! Give me 15 Min......tick tack tick tack....
smileys with beer
September 27, 2010 06:11PM
OK!
RapidsharePlugin v1.1.1 works fine thumbs up
smileys with beer
September 27, 2010 06:36PM
Thank you ntoskrnl for the quick fix!
September 27, 2010 06:58PM
EDIT:
It was completely my mistake. This rapidshare problem didn't work couple hours ago with specific error,now obviously you fixed it.
Thank you so much
Cheers
Edited 1 time(s). Last edit at 09/27/2010 07:09PM by mentolija.
