[smiling smileySolved by v1.0.6]FileSonic doesn't work
Posted by splashgame
November 06, 2010 02:16AM
FRD: 0.83u
FileSonic: 1.0.5
It seems FileSonic changes its website today. When the timer counts down to zero, it starts count-down again, and again...... While it is completely okay to download by using browsers.
Test url: [www.filesonic.com]
Thx.
Edited 3 time(s). Last edit at 11/12/2010 06:41PM by splashgame.
Re: FileSonic doesn't work
November 08, 2010 05:55AM
I have the same problem.
November 08, 2010 07:27AM
Me too~~~
FRD:0.85alpha4
FileSonic: 1.0.5
November 09, 2010 06:29PM
Plugin v1.0.6 should fix this.
November 09, 2010 09:48PM
1.0.6 does the trick. Thx. But it is only partially solved the issue.
For individual download, the latest version 1.0.6 works like a charm. But for download queue (which means you have more than 1 download in the queue), once the 1st one is finished download, the next in the queue will give the error message: "Parameter tm was not found". I am using 64 bit Windows 7, and the Java version used by FRD is also 64bit, SE 1.6.0_20-b02. The major reason is that the time interval for free user is more than 1 minute, and the FileSonice website only shows how many minutes remains, only when the time is small than 1 minute, it then starts to count down. Can you look into this problem?
Once again, thx for the hard working~
Re: [Partially Solved by v1.0.6]FileSonic doesn't work
November 11, 2010 07:09PM
This should be fixed in plugin v1.0.7.
November 12, 2010 06:41PM
Great!, It solved the problem, Thx. Keep up the good work~
