how to compile project into frp?
naruto02514
naruto02514
November 12, 2010 02:34AM
im using IntelliJ IDEA ,but i dont know how to compile project into frp file.......
can someone teach?
ntoskrnl
Re: how to compile project into frp?
November 12, 2010 09:32AM
Admin
Add build.xml from plugin SVN root to Ant tasks (open the Ant pane on the right and press the '+' button), then run manualBuild task and write plugin's name into the box.
