www.2shared.com Problem
November 21, 2010 11:41AM
Hi
Trying to download from www.2shared.com. it is raising some problem. i am using 0.85u build 555. the details of log is added as attachment
Regards
Nagaraj
open | download - app.log (74.6 KB)
Re: www.2shared.com Problem
November 21, 2010 11:51AM
The plugin is broken, but you should also not extract a new version of FRD over the previous one.
November 21, 2010 11:59AM
Hi
I have put the new version in a new directory and not on the old one. how to fix the plug in now.
Regards
Nagards
November 21, 2010 02:02PM
I will fix it when I have time.
November 23, 2010 11:01AM
OK, fixed in plugin v1.0.10.
November 23, 2010 11:09AM
Hi
Thanks for the quick reply. sorry to bother u again. Facing Same Problem but with different message telling file does not exist.
Log file is attached.
Regards
Nagaraj
open | download - app.log (57.8 KB)
November 23, 2010 11:29AM
1. No such errors in log.
2. You are using Java 1.6.0_06 which was released in 2006. I am actually surprised that FRD even starts with it. 1.6.0_22 is the newest.
3. You extracted the new version of FRD in the same folder as the previous one.
November 25, 2010 02:47AM
Hi
Regards
Nagaraj
open | download - app.log (58.4 KB)
November 25, 2010 10:39AM
Plugin v1.0.11 should work for a while again.
December 20, 2010 05:27AM
I'm using 0.85 Build #555
It worked yesterday, but not today.
[www.2shared.com]
Error - No string between between 'var key=" and ";' was found - attempt 1
20 Dec 2010 7:03:07 AM cz.vity.freerapid.gui.managers.UpdateManager generateUpdateData
INFO: id = 2shared.com oldVersion = 1.0.11 newVersion = 1.0.11
Edited 1 time(s). Last edit at 12/20/2010 05:28AM by Max337.
