problem: no more plugin update
Posted by roujio87
December 03, 2010 03:31PM
Hi!
Since I have the FRD 0.85 i have no more plugin update. Even so for example the plugin version for fileserve.comon my computer is 1.1.7 and not 1.1.11.
I already tried to update manualy, i runed in administrator on Vista and i moved FRD away from program files...
Any others ideas ?
P.S. sorry for my bad english
Re: problem: no more plugin update
December 03, 2010 03:48PM
Are you running build 555? Older builds had some issues with this, so please update if you don't have 555.
December 03, 2010 05:13PM
thanks for the fast reply ! Problem solved !
