Problems with the vimeo plugin
December 28, 2010 02:47AM
I am a great fan of FreeRapid currently using FreeRapid 0.85 555
and using this plugin for vimeo
x u c plugin ID version service Auther max DL priority
+ + + vimeo.com 1.0.2 vimeo.com ntoskrnl 10 100
trying to download any vimeo video in the last week resulted with the error messege
"ERROR - Video dimensions not found"
an example of such a download is
http://vimeo.com/18081310
another problem with the plugin is that it only identifies videos if they are presented in the format above, however some videos belong to groups and can be found while surfing in a different format
for example
http://vimeo.com/groups/56002/videos/18213719
http://vimeo.com/groups/thearts/videos/18110928
which aren't downloaded
and are identical to
http://vimeo.com/18213719
http://vimeo.com/18110928
which get downloaded.
Thanks,
Snufkin
Re: Problems with the vimeo plugin
December 29, 2010 01:38PM
Thanks for the detailed report.
Plugin v1.1.0 should work again. Those "group" links should also work now.
December 29, 2010 11:38PM
thankssssss men!!!
i wanted to post on it but didnt have much time :)
June 27, 2011 08:38PM
Hi, would it be possible to download a private Vimeo video embedded in a page like this one..??
http://vimeo.com/18809446
It doesnt seem to work for me. Im using frd 8.5u1, vimeo 1.1.0.
I hope its ok to post in this thread since its Vmeo related. Also big thanks for all the work on FRD and its plugins!
