Rapidshare plugin problem
January 18, 2011 10:19AM
Hello
Firstly let me thank you for this amazing program that i started using for a year now.
I have a problem with rapidshare.com. From the moment I upgraded to 0.85u1 rapidshare was not working. It would not pick up the link with clipboard monitoring, neither with manual add (it gives me the message: Following URL(s) are not supported by download plugins)
Today I decided to try and fix it. So I have tried deactivating & activating again the RS plugin but didn't help. Also I tried deleting the RS plugin from the plugin folder & then downloading & installing it with the 'check for new plugins' function. This didnt work either. Finally I downloaded & used the newest version build #566 but didnt work.
I am using windows 7 and Sun Java version 6 update 20 (build 1.6.0_20-b02). Other plugins work fine.
Any help would be greatly appreciated.
Edited 1 time(s). Last edit at 01/18/2011 10:20AM by ziamond.
open | download - plugin folder.jpg (106 KB)
open | download - plugin settings.jpg (134.1 KB)
Re: Rapidshare plugin problem
January 18, 2011 11:44AM
we need to see your app.log file from FRD home folder with your logged problem. Free or premium plugin?
Edited 1 time(s). Last edit at 01/18/2011 11:45AM by Vity.
January 18, 2011 12:42PM
It is for the free plugin. Do not hold a premium account.
Example of rapidshare link: [rapidshare.com]|334tl3|343799935|05._Krkat__b_ba.part1.rar|157286
Pasting you the entire contents of app.log:
Jan 18, 2011 12:06:43 PM cz.vity.freerapid.utilities.LogUtils processException
SEVERE:
java.lang.IllegalStateException: cannot open system clipboard
at sun.awt.windows.WClipboard.openClipboard(Native Method)
at sun.awt.datatransfer.SunClipboard.getClipboardFormatsOpenClose(Unknown Source)
at sun.awt.datatransfer.SunClipboard.getAvailableDataFlavors(Unknown Source)
at cz.vity.freerapid.gui.managers.ClipboardMonitorManager.run(Unknown Source)
Just for the history: when I originally downloaded the 0.85u1 it was in the same folder with 0.83u1. Today i deleted the older version folder. Telling you this in case it is important.
Edited 1 time(s). Last edit at 01/18/2011 12:47PM by ziamond.
January 18, 2011 01:02PM
I found the reason or a workarround:
I was copying the URL from the URL browser box which had this format: rapidshare.com/#!download|334tl3|343799935|05._Krkat__b_ba.part1.rar|157286
When I looked in the rapidshare page there was another link in:
'You want to load the following file' : rapidshare.com/files/343799935/05._Krkat__b_ba.part1.rar THIS LINK WORKED
The 2 URLs have different syntax
I noticed that RS changed the layout of their download link pages. Is there a mistake on my behalf or FRD ?
Thanxs
Edited 3 time(s). Last edit at 01/18/2011 01:07PM by ziamond.
