[SOLVED]Uploading problem (v1.5.11)
March 12, 2011 09:26PM
Frd: 0.85u1
plugin: 1.5.11
test url: [uploading.com]
error: No string between 'get/' and '/' was found.
other: web browser downloading just works fine.
Once again, uploading.com changes its website design just a little bit,.....,
Please take some time to check it out, thanks.
Edited 1 time(s). Last edit at 03/27/2011 05:06PM by splashgame.
Re: Uploading problem
March 24, 2011 06:50PM
I have a solution for this, I am just having trouble where my compiled files went. For now though , make Sure you have a trailiaing / at teh end of your link
[uploading.com] will NOT work
[uploading.com] WILL work
.....until i can somehow comit those files or something :-p
March 25, 2011 07:47AM
That uploading plugin should work for you, let me know if it doesnt
open | download - uploading.frp (5.8 KB)
March 26, 2011 10:34PM
hi, capcap
That does the tricky, and works like a charm!, you rock, man! Thx ~
Edited 1 time(s). Last edit at 03/26/2011 11:52PM by splashgame.
