MegaUpload Premium not work (ntoskrnl )
April 21, 2011 01:59AM
I have a megaupload premium, but is not work on FreeRapid.
The problem started 3 days ago, the account work fine in other files managers.
FreeRapid v0.85u1 build 566
Plug version 1.0.6 - Autor: ntoskrnl
Print:
Re: MegaUpload Premium not work (ntoskrnl )
April 22, 2011 11:11PM
I have megaupload premium 3 months, functioned normally for 2 months.
Please man, this is the only manager that works perfectly on linux.
April 23, 2011 06:18AM
Did you enable direct downloads on the MegaUpload site? That is difficult to support in the plugin. If you did, please disable it.
If it still doesn't work, you'll have to provide me login details so I can test and fix the plugin.
April 23, 2011 02:09PM
Direct downloads was activated, I disabled and is now functioning normally.
not aware of this detail.
Thanks man, disregard the PM I sent you.
Thank you once again, nice work on this program!
Edited 2 time(s). Last edit at 04/23/2011 02:21PM by normand_korn.
