Depositfiles 1.2.8 Severe Issue
Posted by Nelapsi
October 19, 2011 01:16PM
The previous issue had a work around this does not and since I finally figured out a way to make this frd and win 7 give me a log I decided to post here in its own thread.
Hope we can get this resolved quickly
open | download - app.log (25.2 KB)
Re: Depositfiles 1.2.8 Severe Issue
October 21, 2011 10:38PM
Any chance of getting this looked at?
October 23, 2011 03:08PM
Fixed here: [wordrider.net]
October 23, 2011 03:20PM
Thanks, just tested it.. both the required editing of the initial link with /en or any other language code and the new error with load_form() fixed.
Not sure if plugin related but going to state it...
Every file after the first has had a connection problem though can access it on the normal website. Might be something with DF though so not jumping to conclusions without others testing it or more time.
Edited 1 time(s). Last edit at 10/23/2011 03:29PM by Nelapsi.
October 23, 2011 03:54PM
Found the error in the new plug in logic.
It will successfully download the file but when it goes to check on the next file and if there is still a time on the delay between file downloads, the plugin will register an error and problem with connection.
