Depositfiles 1.3.1 Severe Issue
October 25, 2011 02:57PM
Got a problem with connection, cannot find requested page error.
This just happened this morning half way through a list, I checked a few of the files on the web browser and all seemed find so I am guessing they had a change take place.
Re: Depositfiles 1.3.1 Severe Issue
October 25, 2011 08:32PM
Hi, it may be my mistake while updating plugin... (I removed some captcha code) :(
When I worked on it, the depositfile server does not require captcha, and now... yes :/
I will test and try fix it later
October 25, 2011 11:00PM
doing a great job!!! thank you as always
October 25, 2011 11:30PM
Thanks for your response..
Honestly you had it right for what they had, I think they just put the change in this morning.
October 26, 2011 08:55AM
You're right, it's just new changes on the depositfile server :)
(old captcha code I removed was very outdated and it did not matter)
And now, please check the attached update:
- patch - for developers,
- compiled plugin - for impatient users ;)
open | download - depositfiles_1_3_1.patch (4.3 KB)
open | download - depositfiles.frp (6.2 KB)
October 26, 2011 09:11AM
Fixed in plugin v1.3.2.
October 26, 2011 10:09AM
Updated, Tested and Working
Thank you very much :)
October 31, 2011 06:08PM
Hi, I have a problem with downloading from depositfiles.com.
My FRD version is 0.85u1. I don't know the exact version of deposit plugin, but it's the last one (not that on the forum earlier on this page, but from the FRD-Help-Check for new plugins...). After the downloading of this last version of plugin, it works for about 24 hours, and now, for almost a week already, most of the files shows "ERROR-file is not available anymore" (but it IS available - checked through the web browser), and less of them shows "ERROR-Problem with a connection to service. Cannot find requested page content". I can't understand what happened, and I don't know what to do.
October 31, 2011 06:27PM
Please can you provide the links you have problem with?
October 31, 2011 06:55PM
I guess you checked the availability of your file using a web browser?
Please note, that some errors show up AFTER clicking on the "FREE downloading" button. Please check it first.
