problems with LETITBIT
Posted by romchik
December 14, 2011 04:31AM
FRD 0.86u1
plugin letitbit.net version 1.3.8
author Lukiz+ntoskrnl
ERROR - No number between 'seconds =' and ';' was found
[letitbit.net]
[letitbit.net]
[letitbit.net]
[letitbit.net]
[letitbit.net]
[letitbit.net]
I can't dowload any file from letitbit.net about 3 weeks :(
Edited 1 time(s). Last edit at 12/15/2011 05:26AM by romchik.
open | download - app.log (214.5 KB)
Re: problems with LETITBIT
December 24, 2011 08:14AM
After plugin update (version 1.3.9) i have the same problem : ERROR - No number between 'seconds =' and ';' was found :( I don't know what to do.
Edited 1 time(s). Last edit at 12/24/2011 08:15AM by romchik.
December 24, 2011 06:52PM
Works just fine for me.
January 07, 2012 10:00AM
Plugin does not work for the Russians IP, as I understand.
You can fix it?
tnx.
January 07, 2012 03:04PM
Well, I'm not Russian, so I can't reproduce the problem.
If you post your app.log after such an error, I may try to fix it.
January 07, 2012 05:30PM
it's file [letitbit.net]
and its log from Russia.
But from another country (Latvia) downloading without problems (only need to enter captcha).
open | download - app.log (26.9 KB)
open | download - app_latvia.log (125 bytes)
January 07, 2012 05:48PM
That app.log only contains "java.net.UnknownHostException: letitbit.net" which means connection problem (unrelated to FRD).
January 07, 2012 06:40PM
this is strange because browser is downloading.
There is a log with the firewall turned off, check it (now error No number between 'seconds =' and ';' was found )
open | download - app.log (29.5 KB)
January 07, 2012 06:58PM
Please try plugin v1.3.10, and if it still doesn't work, please post a new app.log with the new plugin.
January 08, 2012 06:22AM
Thanks, it worked.
ntoskrnl , you are the best!
how do you manage to make these plugins... smiling smiley
