file handling problem
Posted by malath84
February 14, 2012 09:04AM
Hello all,
I really would thank you for this great project..
I've noticed a bugs,
case 1: I can't open files (execute) after it finished downloading, e.g. [rapidshare.com]
case 2: I can't open directory of the downloaded file has non-English characters, e.g. [www.4shared.com]
the second file has both cases
Thanks in advance.. thumbs up
Re: file handling problem
February 14, 2012 09:22AM
Case 1: Works fine for me.
Case 2: I can confirm the issues. We'll see what we can do about this.
Which operating system are you using by the way, and which version of Java do you have (Control Panel > Java > About button)? I have Windows 7 and Java Version 6 Update 22.
Edited 1 time(s). Last edit at 02/14/2012 09:23AM by ntoskrnl.
February 14, 2012 09:31AM
Then how to identify my problem about case 1?
OS Version: Microsoft Windows XP Version 5.1.2600 SP3
Java Version: 6 Update 29
February 14, 2012 09:33AM
Please upload your app.log file.
February 14, 2012 09:55AM
here is the app.log
does it matter I'm running the frd.exe from a path that contains space "C:\Program Files\Downloaders\FreeRapid", for case 1?
open | download - app.log (4.9 KB)
February 14, 2012 09:57AM
Do you have Arabic characters in the folders in which you have saved your files?
So far this seems to be a bug in Java, and we can unfortunately do nothing about it.
Edited 1 time(s). Last edit at 02/14/2012 09:58AM by ntoskrnl.
February 14, 2012 10:02AM
No at all, but it does contain space "D:\My Documents\Downloads\FreeRapid", although no problem for other English files in the same folder..
February 14, 2012 10:44AM
Actually before this FRD's release there were no problem in Arabic directory or filenaming at all, I'm using FRD since version 0.81.
I just noticed this issues in recent versions..
February 14, 2012 10:45AM
There were no changes in this manner , you just didn't notice that.
February 14, 2012 10:51AM
Then, What the problem should be?
