DepositFile issues (?)
April 27, 2012 10:13AM
Hi guys and many thanks for the great job.thumbs up
My prob is since yesterday, in 0.86u1 version, any links from depositfile is added under the name "file-name" without extension instead of "Men in Black.avi" for instance.
So I end up with numerous lines with "file-name" written on and on, one after the other, so every downloaded file is replaced by the next since they're all named "file-name", and even if I manage to save them i cannot know if it is a .avi or a .rar or anything.
I tweaked & twitched about everything, try de- and re-install, updated everything, the app, the sun java machine, and so on.
Nothing changes for deposit file when it worx all right with others like Oron.
I don't get it and it's turning me crazy hot smiley
Thanx a lot for the concern, app.log is attached with a screen cap of what appears in FRD.
open | download - screencap.jpg (415.7 KB)
open | download - app.log (12.4 KB)
Re: DepositFile issues (?)
April 27, 2012 10:31AM
Plugin v1.3.3 should work again.
April 27, 2012 11:55AM
thanks a lot, everything seems back to norml
thx again, c u soon...
April 30, 2012 08:48AM
I have the same problem with FRD 0.86u1 version and DepositFiles.com_premium 1.0.3 plugin.
April 30, 2012 08:58AM
April 30, 2012 12:18PM
Password for premium account in your PM.
April 30, 2012 01:26PM
Plugin v1.0.4 should work again.
April 30, 2012 01:52PM
Thanks a lot!
June 02, 2012 11:57AM
Hello there ! me again with the very same problem !
Except that i changed my dying wrecked PC for a brand new one with new O.S W7 family premium 64b, which i don't think is the source of the problm.
This time beside the "file name" issue with all Depositfile downloads (when Oron works) it's written : ERROR-cannot create directory- . (which means i can't download at all)
Thanks anticipated...
Edited 1 time(s). Last edit at 06/02/2012 11:58AM by turlusiphon.
June 02, 2012 12:00PM
What's the link you are trying to download.
Also check your access rights to the target directory.
