Cancel functionality (button) creates serious problems
Posted by BigPuppy
April 14, 2013 12:12AM
Hi guys,
Thanks for nice program.
At the same time it has SERIOUS problems in functionality chart. For example:
1) Just an accidental hit of the Escape button (on the keyboard) completely destroys downloading in the line selected! No warning, no confirmation asked! And for many file hosts there is no way to recover that destroyed downloading...
2) The Cancel button in the front-end pretty often do the same. Or it deletes not only the record, but also the file which was successfully downloaded! Such strange functionality with extermination of the downloaded file is NOT inline with the definition of the word "Cancel". Not to mention that extermination of successfully downloaded file should be available with many warning notes and only as a separate, specifically mentioned operation (or even not available at all inside the program).
I can provide you with more bugs and suggestions.
P.S.
Feel free to answer in Russian, if it is more convenient for you.
Re: Cancel functionality (button) creates serious problems
April 14, 2013 04:56PM
ad 1) that's what cancel buttons do. Simple advice - don't hit wrong buttons by accident.
2) check this out:
For us it's not strange and we are satisfied with current state.
Provide as many as suggestions you want.
PS. We don't speak Russian.
Edited 1 time(s). Last edit at 04/14/2013 04:57PM by Vity.
