shell frontend
Posted by alex.blackbit
shell frontend
June 09, 2009 12:56PM
are you planning to create a shell frontend for freerapid?
that would be very useful for starting downloads e.g. at home from a pc at work.
Re: shell frontend
June 09, 2009 12:58PM
Sometimes in the future, but it has not a priority.
You can use VNC in much easier way than writing commands to console.
Re: shell frontend
June 09, 2009 01:04PM
thanks for your answer, but i cannot use vnc.
wasn't there a simple shell utility that does that? with less featues than freerapid... i forgot the name.
Re: shell frontend
June 09, 2009 01:08PM
Try SlimRat.
Re: shell frontend
June 09, 2009 01:21PM
thanks.
Re: shell frontend
March 20, 2011 11:02PM
Any updates regarding console interface for FreeRapid?
Re: shell frontend
March 21, 2011 04:53AM
No.
