ctrl-enter no longer works properly with java 8.65
December 12, 2015 11:03PM
a neat feature of freerapid downloader was that if i pushex ctrl+enter it would open the directory where the files get stashed.
since java 8.65 if i do so with a file that had been downloaded and is present on the disk it still works.
If, however, i try to do so with a file that has been deleted or that still needs to finish downloading it hangs up the program. At which point the only solution is to kill it via task manager and restart it.
This issue started for me with the update to java 8.65
I've tried it on 3 computers with the same results.
Re: ctrl-enter no longer works properly with java 8.65
December 13, 2015 05:21AM
Works fine here: Lubuntu 14.04 32bit, Java 1.8.0_66, with PCManFM as file manager.
What operating system are you using? Please attach app.log (Help->Browse to log file).
Edited 1 time(s). Last edit at 12/13/2015 05:22AM by tong2shot.
December 13, 2015 10:28AM
I'm using windows 7 SP1 java SDK 1.8.0_65 standard file manager for windows (explorer)
the log seems empty. i tried to download a file, then delete it, tried to ctrl-enter and hung the application, then killed the frd, checked the log and there was nothing inside, a 0 byte file. so i restarted and now there's just one line inside. I'll attach it for good measures.
open | download - app.log (102 bytes)
