Window positioning and dimensions
Posted by UpDown
August 13, 2009 03:17PM
This is a well-thought out program that does what it says it does. Kudos.
My only small wish is that it would remember it's position from one running to the next. I've tried to get UltraMon to place it on the second monitor upon running several different ways, but the program over-rides this and always opens at 0,0 on Monitor One. It's only a drag and a resize to get what I want, but my hope is that you would consider having persistent locations allowed for the program.
Thanks, and keep up the good work
Re: Window positioning and dimensions
August 13, 2009 06:27PM
Did you try to use 0.83beta? It might be fixed in this version.
August 22, 2009 01:58PM
Indeed, the beta DOES remember the window positioning. Don't know if it's my Ultra-Mon setting, your setting or a combination of both, but it starts quickly in the right place with the right dimensions. Thanks a lot for continuing to do what you do best ... which is to create very useful software.
