Switch Connection Upon "X" amount of failed connections
Posted by Solace
October 16, 2009 09:15PM
pretty simple request of having the program switch to a new proxy/connection after X amount of fails. currently it just stays on on the default connection for that downloader service and will retry repeatedly. Reason for this is sometimes on certain proxies it will respond some errors where it just will keep retrying but never succeed "not cause the proxy is bad" haven't been able to figure out why sometimes it will do this. currently you have to "cancel the download" and resume it manually for it to choose a new connection.
also allow the program to exceed the limit of 9 max downloads i found the .xmls containing the info to change it manually tho.
and for win 7 its not creating the registry entries in the location that was described on your page. and this is on the RC2.
Edited 2 time(s). Last edit at 10/16/2009 09:28PM by Solace.
Re: Switch Connection Upon "X" amount of failed connections
October 17, 2009 03:52AM
> connection.
You should use working proxies. Proxies are already rotated. Every download should try to start using default connection as first (because it's the fastest one).
I won't do that. 9 is enough to prevent DOS attack and there are other reasons too.
See changes in 0.83 - dependency on registry was removed in 0.83.
Edited 4 time(s). Last edit at 10/17/2009 04:01AM by Vity.
