FRD Portable
March 24, 2012 11:58PM
I am using FreeRapid Downloader I think it would be great if you can make this app portable.
So I can put it on usbkey and bring FRD, downloads, and preferences everywhere...
Maybe only let user set where are configuration files located could work ?
Thank you.
Edited 1 time(s). Last edit at 03/25/2012 12:04AM by koxy.
Re: FRD Portable
March 25, 2012 08:45AM
FRD is portable since version 0.65...
See readme.txt or our documentation section.
Re: FRD Portable
March 06, 2015 05:18PM
Is there a way to make an existing installation truly portable without losing my settings?
I mean something like moving the VitySoft folder next to frd.jar
and then run frd.jar -p ?
Re: FRD Portable
March 06, 2015 05:29PM
Yes. If you copy the contents of "%appdata%\VitySoft\FRD" to a folder called "config" next to frd.jar, you can run it as portable with your existing settings.
Re: FRD Portable
March 06, 2015 05:48PM
thank you ntos
