#8: Use smart clipboard monitoring
November 07, 2009 05:35PM
I will show you how easy is to add your links from browser to FRD, you don't even need to see whole links "http://...." on screen!
1. First, check clipboard monitoring in FRD - in menu Options->Clipboard monitoring is checked
enable clipboard monitoring is indicating this active icon in statusbar (btw. did you know that this icon is clickable? smiling smiley ):
2. Go to the browser
and select by mouse links you want to add:
3. Press Ctrl+C to copy selection into clipboard (you can alternatively use right mouse button -> copy to clipboard in your browser)
4. FRD window with your selected links is activated:
5. Press Start to begin download
Edited 4 time(s). Last edit at 11/07/2009 05:48PM by Vity.
Sorry, you can't reply to this topic. It has been closed.
