jim
bugs/problems ?
May 06, 2006 02:14PM
I am using Wordrider 0.75 and I came upon problems :
- When I write text in small or large fonts and I want
to write an index or an exponent, when quit the exponent,
or index mode, the font size comes back to normal
font.
It would be more convenient if it came back to the
original font used.
- The automatic line feed adds sometime a space at the
begining of the line.
- In uview the index and exponant in small or large
fonts fonts are dispayed as normal small or large
letters.
When I save a text on wordrider I loose these index or
exponent properties.
- When I write a formula after a line in small fonts,
the formula is not dispayed.
I have to add a line in normal fonts to work around the problem.
- The accent in french (?©, ?±, ...) are not displayed on
uview for small fonts.
Best wishes.
Jim.
Re: bugs/problems ?
October 20, 2006 09:38PM
Hello Jim, I didn't notice your post. I am deeply sorry.
font.
original font used.
Yeah. You're right. The problem is that viewers use different behaviour againts eg. MS Word. I am not simply to able recognize from which font size it came from, because subscript style (exponent style) use MINI font size. I spent a few hours to find some workaround or some simple solution. Unfortunately I didn't find any at this time sad smiley.
Can you be more specific please? Can you reproduce problem "step by step"?
letters.
UView is compatible to TxtRider tags, which has less count of formatting tags. Subscript is supported only in Hibview.
Hibview has additional tags for #D : subscript, #J : conjugate, Mxxx : margin xxx pixels. These tags are removed during saving of files or they are converted to similar ones (subscript->mini font size).
I guess, that this is fixed in the latest version of uView. Please look at this page:[membres.lycos.fr]
That's because calcs have small resolution of screens. It's not possible to view such small accents. No calc viewer supports it.
I hope that i helped you to solve at least one problem.
Edited 1 time(s). Last edit at 10/20/2006 09:41PM by Vity.
jim
Re: bugs/problems ?
October 21, 2006 04:14PM
Thanks Vity for your answer.
As far as I understand the small fonts should not be used.
"- The automatic line feed adds sometime a space at the
Can you be more specific please? Can you reproduce problem "step by step"?"
It's a long time since I posted the questions, so I don't remember exactly the sequence that made a problem. I will probably ask you the question again within a few months.
Do you still develop Word rider ?
Jim.
Re: bugs/problems ?
October 21, 2006 04:30PM
At this time I can say yes. I know it's a long time when i released last version of WordRider. I spent a last year working on Damaq.
I am currently working on the next version of WordRider. I will release an alpha version probably this night or tommorow. I guess it might be still a bit unstable, because
I made a lot of intern changes in this version (min JRE version will be 1.5). I will need testers! smiling smiley
Other major changes:
* Find/Replace dialog (see news on homepage)
* Sending files to calculator via Ti Connect or TiLP
I would also like to add a support for Notefolio into the final stable version.
Edited 1 time(s). Last edit at 10/21/2006 07:19PM by Vity.
jim
Re: bugs/problems ?
October 24, 2006 11:22AM
That's a great news.
I will test the new version.
