Won't send
April 27, 2007 01:27AM
I tried sending it to my calc (TI 89 TI HW 3.0 OS 3.10, Hardware 3 patched) with TI Connect X (1.6 (19) ) and it claims "The Object can not be sent to the selected device because it is intended for a device with a newer OS. Update the device OS and Try again." I'm trying to do this Mac Os X Tiger 10.4.9
Re: Won't send
April 27, 2007 07:39AM
Hello hdofu,
Try to open and save generated file with TI-Graph link. I'm not sure if TI-Graph link is present in TI Connect X distribution on MacOS.
You can also try to use some hex editor and change first bytes in the file from '\*\*TI92P\*' into '\*\*TI89\*\*' or '\*\*TI92\*\*'.
I hope it helps.
Please write me back if it will help to you.
Vity
Re: Won't send
April 27, 2007 10:27PM
I tried renaming it and now it tells me it contains data that is not supported by the os ><
Re: Won't send
April 27, 2007 10:35PM
Hmmms. That's weird. Can you send me the file? (admin@wordrider.net)
I'll try to analyze it.
You can also try to use TiLP utility ([lpg.ticalc.org]]) for sending files.
Vity
Edited 1 time(s). Last edit at 04/27/2007 10:56PM by Vity.
Re: Won't send
April 27, 2007 11:06PM
sent you the file, tried tilp earlier today to, won't send, tried sending with my mini usb to usb conection,
Re: Won't send
April 27, 2007 11:15PM
I checked it, you missed one star in the header.
Please try to send demo file (it's included in this post as attachment)
I still hope that there is problem with header.
open | download - test.89t (6.3 KB)
Re: Won't send
April 27, 2007 11:37PM
Tried sending that file, Still got the error ><
Re: Won't send
April 27, 2007 11:49PM
Hmmmms.
Yet another idea: Try to create 89t in the calculator - press APPS button, then 8 (Text editor), 3 (New...) type variable name and a few characters.
After that move the variable (file) via TI Connect into your comp and upload it here please. Maybe they made some changes in the specification of variable in the newest version of OS.
Try to send that file back too.
Your problem has to have some reasonable explanation. smiling smiley
Edited 1 time(s). Last edit at 04/27/2007 11:52PM by Vity.
Re: Won't send
April 28, 2007 12:00AM
Ok, sent
open | download - oncalc TI-89 Titanium.89t (130 bytes)
Re: Won't send
April 28, 2007 12:22AM
Thank you for your cooperation. I'll inspect it tommorow (=today) morning. I'm already too tired today, here is 2:25AM smiling smiley.
I guess we are getting closer to solution.
Edited 2 time(s). Last edit at 04/28/2007 12:23AM by Vity.
