WordRider is not saving to my TI-89
Posted by DeanDalton
December 13, 2006 04:53AM
When I go to save a file I created with a bit of text and a photo it is not coming up with a path to my TI-89 or Calc. The file goes to a number of choices but calc. is not one of them as shown in the tutorials.
I have installed Preos, Txtrider and hibview on to my PC and everything seems to be ready to go. But again when I creat a file in WordRider and go to save it there is no choice or path to my calc.
Also, shouldn't there be some sort of icon on my TI-89 main screen?
Re: WordRider is not saving to my TI-89
December 13, 2006 09:35PM
Hello Dean again smiling smiley,
I am not sure if I understand you well. Do you have a problem with sending generated files (89t, 89i...) to calc with TI-Connect (as showed in tutorial)? Or do you mean some potential bug in WordRider? WordRider does not save files into calculator directly. You have to use TI-Connect for it. You can try to use WordRider 0.8alpha. It runs TI-Connect automatically (main menu File->Send).
No, nothing like that.
Regards
Vity
