Charts, Graphs and Schematics
December 13, 2006 12:55AM
I just installed Wordrider 0.75 on my lap-top PC. I am not the most computer literate person so please bear with me...
I have used NoteFolio on my TI-89 for college and I thought it was a great program but wanted more. I think I found it with WordRider!
What I really need is a way to get simple charts, graphs and schematics to my TI-89 for retrieval later... like during college exams. I see that I should be able download JPG type photos into the WordRider program and then I should be able to send the photo to my TI-89. Obviously the picture quality on the TI-89 is not going to be good, but that's ok. I think.
My question is this. I have a bright white eraser board where I could quickly draw the needed charts with a thick dark black marker. Could I simply take a picture of the chart with a cheap digital camera, send the JPG to my PC, then to the WordRider document and then to my TI-89? I know it kind of sounds like a lot of work, but the initial creation of chart itself would be easy.
If anybody has any other suggestions, I am open to them. Does anybody know of a cheap program that I could use to draw the charts? A very cheap drafting type program that will be compatible with WordRider? I would really like a program that easily lets me draw with my mouse orthographically.
Also, I have version 0.75, should I switch to 1.5?
Thanks,
DeanDalton@aol.com
Re: Charts, Graphs and Schematics
December 13, 2006 09:22PM
Hello Dean,
You can use any bitmap editor for creating pictures (eg. MS PaintBrush) you want. These pictures you can easily import with a dialog for importing pictures (Ctrl+P) or via system clipboard (Ctrl+Shift+P). For short presentation how to convert JPG see "WordRider in Action" tutorial in documentation section.
I guess you will have a bit problem with viewing graphs correctly, because calculator's resolution is very low.
WordRider is not intended to work with large pictures (all functions would be slow) therefore I recommend you to resize them into smaller sizes as first before converting into 89i.
> 1.5?
There is no WordRider's version 1.5 smiling smiley. Not yet smiling smiley. Just 0.8 alpha (testing) version smiling smiley.
There are a few new features like importing Notefolio files. See this topic for more details: [wordrider.net]
Hope this helps.
Vity
Edited 1 time(s). Last edit at 12/13/2006 09:44PM by Vity.
