Max number of breakpoints for one document is 32 in uView? sad smiley
Posted by Hury999
May 20, 2020 12:17AM
So i created one document with more than 32 breakpoints, it works in Wordrider fine with lots of breakpoints but when I transfer that to calculator it only shows me 32 of them in uView. Is max number of breakpoints bounded to 32 or so in calculator in uView? If so, how to expand that?
Thanks in advance!
Re: Max number of breakpoints for one document is 32 in uView? sad smiley
May 20, 2020 07:16AM
Unfortunately I didn't use these tools for ages. Try to find a forum related to this tools, but it's possible it's their limit from some reason.
May 22, 2020 11:15PM
Also if you know, is it possible to mathprint shows uppercase characters, for now if i write uppercase character in input, output(with mathprint) all uppercase characters converts to lowercase, is this possible to change at least in uview for example?
