Issues and suggestion
Posted by icarocd
March 15, 2009 03:42PM
Hi everyone,
First, I thank for the great software.
Bugs (maybe they are, i am not sure):
-speed info's column seems to fluctuate a lot. In just few seconds, it goes from 2kB/s to 30kB/s for instance, but we are sure it doesn't happen like that. Maybe by showing an average between some seconds instead of changing every seconds should looks better.
Suggestions:
-tray icon like in eMule. that is simply perfect.
-max speed control.
-options to hide or show the columns. Some of them are unecessary, some others aren,t. Let us choose what to see.
-sort lines by column criteria. example: by name, by service type, by progress.
Re: Issues and suggestion
March 15, 2009 04:32PM
- eMule
i don't know eMule...
it's already there, an icon on the right top of the table...
March 15, 2009 05:35PM
explanation of the first suggestion:
eMule shows at tray icon the download speed being reached in real time. Of course that the scale must be set according my connection. example: I say to the program that my max download rate is X, then the scale (green bar or something else) in the icon goes from 0 to X, and the bar fills according how much the downloads are using. Simple and nice.
How about the other questions? Sorting of lines seems quite simple to be implemented.
March 15, 2009 05:40PM
Not so easily. It brings many internal problems you can't see.
