Problem using the program maybe java
February 28, 2013 10:11PM
I use the FRD for few year and it IS not work now
it show me this error with the last version and also
with the other one before it..
I will thank for any help..
Error
Message:
com.objectdb.o._PersistenceException: Failed to read the value of field field cz.vity.freerapid.model.DownloadFile.description using enhanced method
Level:
SEVERE
Stack Trace:
com.objectdb.o._PersistenceException.b(_PersistenceException.java:45)
com.objectdb.o.JPE.g(JPE.java:142)
com.objectdb.o.ERR.f(ERR.java:60)
com.objectdb.o.OBC.onObjectDBError(OBC.java:1504)
com.objectdb.jpa.JpaQuery.getResultList(JpaQuery.java:695)
cz.vity.freerapid.gui.managers.DatabaseManager.loadAll(DatabaseManager.java:134)
cz.vity.freerapid.gui.managers.FileListMaintainer.loadFileHistoryList(FileListMaintainer.java:108)
cz.vity.freerapid.gui.managers.FileListMaintainer.loadListToBean(FileListMaintainer.java:113)
cz.vity.freerapid.gui.managers.DataManager.initProcessManagerQueue(DataManager.java:146)
cz.vity.freerapid.gui.managers.ManagerDirector.guiIsReady(ManagerDirector.java:170)
cz.vity.freerapid.core.MainApp.ready(MainApp.java:121)
org.jdesktop.application.Application$DoWaitForEmptyEventQ.finished(Application.java:443)
org.jdesktop.application.Task$StatePCL$1.run(Task.java:1021)
java.awt.EventQueue.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.access$200(Unknown Source)
java.awt.EventQueue$3.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
com.objectdb.o.MSG.d(MSG.java:74)
com.objectdb.o.UMR.P(UMR.java:925)
com.objectdb.o.UMR.B(UMR.java:603)
com.objectdb.o.UML.v(UML.java:549)
com.objectdb.o.UTV.k(UTV.java:173)
com.objectdb.o.UTY.aG(UTY.java:1269)
com.objectdb.o.ENH.b(ENH.java:102)
com.objectdb.o.LDR.J(LDR.java:796)
com.objectdb.o.LDR.z(LDR.java:218)
com.objectdb.o.OBC.aN(OBC.java:1072)
com.objectdb.o.OBC.aL(OBC.java:977)
com.objectdb.o.OBC.UH(OBC.java:815)
com.objectdb.o.SRB.l(SRB.java:158)
com.objectdb.o.QRR.m(QRR.java:543)
com.objectdb.o.QRR.f(QRR.java:210)
com.objectdb.jpa.JpaQuery.getResultList(JpaQuery.java:686)
Java heap space
java.util.Arrays.copyOfRange(Unknown Source)
java.lang.String.(Unknown Source)
com.objectdb.o.BYR.R(BYR.java:1219)
com.objectdb.o.BYR.R(BYR.java:520)
com.objectdb.o.TYR.completeRead(TYR.java:328)
com.objectdb.o.STT.m(STT.java:118)
com.objectdb.o.TYR.readStringValue(TYR.java:880)
cz.vity.freerapid.model.DownloadFile.__odbReadMember(DownloadFile.java:1)
com.objectdb.o.UMR.C(UMR.java:616)
com.objectdb.o.UMR.B(UMR.java:597)
Re: Problem using the program maybe java
February 28, 2013 10:14PM
1. Don't use older versions.
2. FRD restart should help to fix your problem. If not, post here a content of your configuration folder.
Edited 2 time(s). Last edit at 02/28/2013 10:17PM by Vity.
February 28, 2013 10:26PM
Hi thank for your answer
No i restart the program,reset java
and also i traied to run the jr whit the
portable java and it work now..but
i went the exe that will work
I use a clean new version of the program
and also not working..i have win 7
the log file i posted up
thank you
March 01, 2013 05:58AM
"Java heap space"? That's an OOM? I wonder what could cause it.
How many links do you have in the list?
