FreeRapid doesn't start because of my language!!
April 20, 2009 08:50AM
thank U vity for your wonderful program
It really saves more time for me
specially the proxy feature. It works perfect for me.
but I've faced a small problem
I'm from Egypt & my default windows language is arabic
when I start the program, It hangs up & never open.
Then I tried to change my default language from "Regional and Language settings" from Arabic ( Egypt ) to English ( United Kingdom ) then It opened.
I can run the program every time by changing my language but I need my language to run many programs correctly. So it's nice from U to solve this Bug.
Regards,
Re: FreeRapid doesn't start because of my language!!
April 20, 2009 10:23AM
I would like to see your app.log to solve this problem.
April 20, 2009 11:50AM
ok here is it.
ver. 0.82
when I open the program I see the first logo & nothing happen after that.
I tried it on my second PC. The same problem happened.
open | download - app.log (1.7 KB)
April 20, 2009 11:59AM
This is weird, I don't see any problem in the log.
Try to delete mainFrame.session.xml from on this path
C:\Documents and Settings\Mahmoud Saad\Application Data\VitySoft\FRD
and run FRD again
April 20, 2009 12:13PM
ok I did but the problem still happening.
It runs only when I change the language.
Can I do anything to make the program run with english while my windows language is arabic.
I mean editing any configuration file of the program
April 20, 2009 12:28PM
I am not sure if it helps, but go to C:\Documents and Settings\Mahmoud Saad\Application Data\VitySoft\FRD
and edit frd.xml and set from
<entry key="selLanguage" value="AR"/> to  <entry key="selLanguage" value="EN"/>
Edited 1 time(s). Last edit at 04/20/2009 12:33PM by Vity.
April 20, 2009 12:43PM
It works great now
Thank you Vity
