Auto Add URLS with separate destination folders
May 29, 2009 07:25PM
Having a list of URLs, I thought I could write a quick utility for adding new downloads and assigning the Description and Download Folder per each URL. So I open the fileslist.xml file and add the objects in what I thought was the same manner that FreeRapid does when a URL is added via the interface. The problem is that when I restart FreeRapid, it may find the ones I just added, or it may clear out the entire list. Luckily I'm keeping backups.
What are the rules for adding downloads outside of the UI? Is there something else besides fileslist.xml?
Re: Auto Add URLS with separate destination folders
May 30, 2009 01:31AM
It means that you corrupted structure of the file. The file is not intended for manual editing.
June 01, 2009 01:35PM
OK, so is there a way to do it automatically? API, COM? A separate dialog to accept paired URLs and Folders? Anything?
June 01, 2009 08:50PM
>>COM?
Funny winking smiley.
No there is no such interface. Maybe I add something like that in the future (through command line).
Edited 1 time(s). Last edit at 06/01/2009 09:09PM by Vity.
June 01, 2009 09:01PM
An import feature would be great, as well. URL, Folder and Description, separated by tabs.
