FRD won't work in Ubuntu
June 16, 2009 04:25PM
Hi All,
I want to try this program I read on internet about but I can't make it work. My OS is Ubuntu 9.04 and I have Sun Java 6 already installed. I downloaded the file from your website and, as I read in other site (by the way, I'm new with Ubuntu too and I couldn't find clear instructions on how to install this program for non-windows users in the oficial FRD website) I tried to open the 'fdr.jar' file with Sun Java 6 but after seeing the FRD logo nothing else happens. What am I doing wrong?
Re: FRD won't work in Ubuntu
June 18, 2009 11:29AM
Nobody? confused smiley
June 20, 2009 07:06AM
I need to see app.log file.
August 24, 2009 09:22PM
Hello.
I have the analog problem.
my cat ~/app.log
25.08.2009 0:13:27 cz.vity.freerapid.core.MainApp exitWithErrorMessage
SEVERE: errorInvalidJRE
I install sun-java6-jre from arhive.ubuntu.com as sudo apt-get install sun-java6-jre also install manually from [java.com].
August 24, 2009 09:29PM
update-java-alternatives...
Edited 1 time(s). Last edit at 08/24/2009 09:30PM by Vity.
October 15, 2009 04:31AM
I have the same issue in xubuntu. But I was able to track down to it was caused by OpenJDK
To confirm OpenJDK is installed, issue command java -version
java version "1.6.0_0"
OpenJDK Runtime Environment (IcedTea6 1.4.1) (6b14-1.4.1-0ubuntu11)
OpenJDK Client VM (build 14.0-b08, mixed mode, sharing)
Remove that, and install JDK by Sun
java version "1.6.0_16"
Java(TM) SE Runtime Environment (build 1.6.0_16-b01)
Java HotSpot(TM) Client VM (build 14.2-b01, mixed mode, sharing)
I am not an expert in linux, so I have no idea other application may affect by this change.
October 15, 2009 05:53AM
they will work much more properly and faster... (by this change)
November 05, 2009 05:29AM
There is bug in frd.sh.
If you have installed both openjdk and sunjdk, frd.sh searches good version by number, but no checks "Sun".
Not good idea to uninstall all other java machines to run one .jar.
You can fix this error manually, but i did quick&simple:
== startfrd.sh ==
#!/bin/sh
# change to FreeRapid folder
cd /usr/share/FreeRapid
# and start with good java
/usr/lib/jvm/java-6-sun-1.6.0.16/jre/bin/java -Xmx128m -jar frd.jar "$@"
Alexander
/Ubuntu Karmic Koala 9.10/amd64
Edited 1 time(s). Last edit at 11/05/2009 05:29AM by Dr.Stein.
