problem login in RS premium
Posted by ron
ron
June 16, 2009 11:18PM
Hey guys i have a problem ,
i have a rapidshare premium account ,
I have everything setup to download as a RS premium in Freerapid
my problem is , when i go to download a file , a box pops ,with my RS premium user and pass info filled , then i press ok , and then the box pops again with my info filled , then i press ok , and the box pops again and thats over and over again when i press ok.
So i cant download any rapidshare files as premium becouse the box keeps popin out , is there any solution for this ????
pls help!
Re: problem login in RS premium
June 17, 2009 02:56PM
I have the same problem! I have also a RS premium account, but FRD doesn't accept that (I had changed my username and password, but It's still not working)...
If I can fix this somehow, I have two other problems.
1. It writes "getting", but nothing starts to download, the "speed-meter" says 0
2. It writes some problem about java heap (I'm sorry, I can't remember it properly)
Can you help me? I really like this software...
June 17, 2009 03:10PM
Hello.
I have similar experience.
Downloading as premium user via web browser (Firefox, IE 6.0) works fine.
Also downloading with FRD as a free rapidshare user works.
But when I am downloading as premium with FRD, I see only GETTING and no download starts.
Few months ago I used another download manager - RapGet - so I tried it today again
and bad surprise - RapGet does not work also.
Maybe there is some change in rapidshare API?
I hope developer of rapidshare plugin will fix this problem soon.
Thanks very much.
P.S.
Error mentioned by virgogirl80 looks like: see attached file.
open | download - frd-err.JPG (40.7 KB)
June 17, 2009 04:15PM
Thank you, that was it smiling smiley
June 17, 2009 07:09PM
Do včerejška jsem bez problémů stahoval přes PA z Rapidshare.Včera se najednou objevila chybová hláška a stahovat z Rapidshare přes PA nejde.Připojuji obrázek. Už jsem několikrát přeinstalovával program, zkoušel jsem instalaci na dvou počítačích a nic. Neporadí někdo?
open | download - CHYBA-FRD.jpg (53.8 KB)
June 17, 2009 11:22PM
Mám presne ten istý problém :-/
Tak isto som to niekoľko krát preinštaloval a ništ.... A prestalo to z ničoho nič, mal som tam nahádzané veci na download a pri konci mi to prestalo ťahať... Pripájam sa k prosbe eye rolling smiley Help us!!!
June 18, 2009 12:44PM
Ahoj.
Reinstalace nemá smysl.
Problém bude někde jinde, protože (jak jsem psal výše) přestal fungovat i RapGet. Vidím to na nějakou změnu v API u rapidshare.
ron
June 18, 2009 01:58PM
So theres no way to fix my problem ???????? sad smiley
Edited 1 time(s). Last edit at 06/18/2009 01:58PM by ron.
June 19, 2009 09:57AM
I also can not download from my rapid share account. So how do I fix it??????hot smiley
Edited 1 time(s). Last edit at 06/19/2009 09:57AM by 0156.
June 19, 2009 10:34AM
No fix
Edited 1 time(s). Last edit at 06/19/2009 10:37AM by 0156.
