FreeRapid freezes when changing directories.
mike2003
mike2003
August 14, 2015 07:21PM
When I try to change the directory and click on this button the program freezes. Only once it opened the window to select the directory after installation.
ntoskrnl
Re: FreeRapid freezes when changing directories.
August 14, 2015 10:39PM
Admin
Are you sure the window does not appear in the background? You can try Alt+Tab.
If not, can you attach the log file? You can find it in %AppData%\VitySoft\FRD\log\app.log.
mike2003
August 15, 2015 03:34AM
Today it works
