How to overcome this problem ???
Posted by akh
akh
June 25, 2009 03:45AM
I had list of RS & other hotfile link which was in Q...
I will be downloading stuffs from office network, I download 1 file at a time & leave this during night
if RS finishes download & it waits for 15mins for next download, @ this mean time ur program tries to downlaod files from Hotfile or any other domain which is in Q, since these things are using captcha image think that I will nt be there to enter images number / alphabets , there shoud be some waiting time where if no action it should skip to next file
Hope so u understood....
Re: How to overcome this problem ???
June 28, 2009 11:58PM
You could always manually pause all the downloads that needs to manually enter captchas & only kepp the rest of the downloads active when your not at the computer.
- Maby we should have an "up to date" list of what sites that require people to manually fill in(always or sometimes) capchas here on this site.
Or you could write a little program that fills in the captchas for you instead so you never have to fill them in....
June 29, 2009 04:08AM
> site.
It's not possible.CAPTCHAs are linked with IP.
> fill them in....
I would like to have it winking smiley.
July 23, 2009 01:17AM
I got an idea, a timeout to captcha input.
if user don't write the captcha code after ?? seconds FDR skips that file and starts next one.
I don't know if this is possible to implement in FDR future versions or if it's complex or difficult to do.
July 23, 2009 03:49AM
it's already on the todo list.
