FreeRapid doesn't seem to work under macOS Sierra
September 30, 2016 09:45AM
I was used to work with FreeRapid under the earlier OS systems, but after installing Sierra? Problems?
Under the preferences now, no more possibility to check 'other sources'
For me FreeRapid seems to be out, because I keep receiving the message 'dammaged'
Re: FreeRapid doesn't seem to work under macOS Sierra
September 30, 2016 11:51AM
Could you try the "All platforms" version of FRD from the download page and see if it works?
December 27, 2016 11:08PM
I can also confirm that the Mac version doesn't work in Sierra, I get the error '“FreeRapid” is damaged and can’t be opened. You should move it to the Trash.'
The all platforms version doesn't work for me as of late either, it just launches and immediately closes. Though it did work in Sierra for a while, so probably something wrong with my Mac...
Sub
January 08, 2017 09:24PM
Na OS El Capitan se děje to samé co popisuje výše DowloadMan.
Můžete poradit?
January 11, 2017 03:36AM
I was able to fix the all platforms version by restarting, but the Mac version still doesn't work. I'm going to guess support for that one ended around Yosemite or El Capitan?
