FRD will not start
Posted by martyh
FRD will not start
November 27, 2016 11:25PM
A few days ago I updated my Java, and now I can't start Free Rapid Download.
The error message I get when I try to run it is "Error: could not open 'C:\Program Files\Java\jre1.8.0_60\lib\i386\jvm.cfm' "
My curernt Java version is "8 Update 111".
Should I rollback to an earlier Java version, or is there a better fix?
Re: FRD will not start
November 27, 2016 11:45PM
Seems like an old Java version is somehow conflicting with the new one. You could try uninstalling all Java versions (from Control Panel) and then reinstalling the latest version.
November 27, 2016 11:56PM
Thanks. I will try that. The Java website claimed that I had removed all old versions, but there seems to be pieces lieft behind (including several versions of jvm.cfg). I will see if I can get rid of all Java versions with ccleaner or something, and then re-install the new one.
November 28, 2016 12:36AM
I have uninstalled and reinstalled Java, and FRD is now working. Thanks again for your help.
