Clipboard problem
July 23, 2009 05:02AM
Clipboard monitoring causes some strange behaviour here, and I don't know if this is introduced with 0.8.2 version or with my upgrading to Windows 7
i.e. working in PyScripter, I sometimes get "can't access clipboard" error, or using "right click > copy" in some application, data isn't copied to clipboard on random basis (but problem can be avoided if using keyboard Ctrrl-C)
Re: Clipboard problem
July 24, 2009 03:31PM
Vity,
can you look at this problem, as it is present in FRD 0.8.3b1 also
FRD is always in my tray.
If I exit FRD no more weird problems with clipboard, so it must be something with clipboard monitoring
July 24, 2009 04:11PM
Can you please upload a log file from 0.83b?
July 25, 2009 11:06AM
July 25, 2009 11:13AM
I don't see anything special in the log. I cannot do anything with it.
July 26, 2009 03:21PM
Well, I don't see either, and don't know why did you ask for it. I think that it is something with Windows 7. As I said the clipboard stops functioning on random bases when FRD is running. I also can't say how clipboard monitoring works in FRD, but perhaps something is changed regarding it with Windows 7 (7127)
July 26, 2009 06:21PM
Clipboard monitoring checks every XXXms system clipboard. If it finds links then calls the dialog.
There is possible some incompatibility with Win7 and JRE.
If the problem persists, disable clipboard monitoring.
