When I try downloading a file from uloz.to. File presence check succeeds, but when downloading, there is another error in console window:
21:17:24 WARNING: class not visible, no class filter found, lib=file:/C:/Users/Jardik/AppData/Local/Temp/.jpf-shadow/ulozto_captcha@1.0.1.frp, class=class cz.vity.freerapid.plugins.services.ulozto_captcha.SoundReader, this={PluginClassLoader: uid=1944345739; {PluginDescriptor: uid=ulozto_captcha@1.0.1}}, requestor={PluginClassLoader: uid=2032281201; {PluginDescriptor: uid=uloz.to@1.3.16}}
21:17:24 SEVERE: cz.vity.freerapid.core.tasks.DownloadTask@4ba4f70e failed: java.lang.NoClassDefFoundError: cz/vity/freerapid/plugins/services/ulozto_captcha/SoundReader
        at cz.vity.freerapid.plugins.services.ulozto.UlozToRunner.stepCaptcha(Unknown Source)
        at cz.vity.freerapid.plugins.services.ulozto.UlozToRunner.run(Unknown Source)
        at cz.vity.freerapid.plugins.webclient.AbstractFileShareService.run(AbstractFileShareService.java:102)
        at cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(DownloadTask.java:98)
        at cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(DownloadTask.java:42)
        at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
        at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
        at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
        at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
        at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
        at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: class cz.vity.freerapid.plugins.services.ulozto_captcha.SoundReader is not visible for plug-in uloz.to, no filter found for library file:/C:/Users/Jardik/AppData/Local/Temp/.jpf-shadow/ulozto_captcha@1.0.1.frp
        at org.java.plugin.standard.StandardPluginClassLoader.checkClassVisibility(StandardPluginClassLoader.java:611)
        at org.java.plugin.standard.StandardPluginClassLoader.loadPluginClass(StandardPluginClassLoader.java:466)
        at org.java.plugin.standard.StandardPluginClassLoader.loadPluginClass(StandardPluginClassLoader.java:491)
        at org.java.plugin.standard.StandardPluginClassLoader.loadClass(StandardPluginClassLoader.java:372)
        at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
        ... 11 more
21:17:24 SEVERE:
        ... 11 more
