SlimerJS not found
April 05, 2018 08:49PM
I am getting error "SlimerJS not found" when trying to download from ulozto.
Never had this kind of error before, there are no records in this forum using search...
Any way to fix it? Thanks.
Re: SlimerJS not found
April 11, 2018 04:33AM
A robot security page sometimes appears, which has google's no-text-captcha on it
For that type of captcha to work in FRD SlimerJS needs to be installed (see here)
April 21, 2018 06:30AM
tried it, but still failed
Sat Apr 21 13:22:56 ICT 2018 WARNING: Couldn't create fir C:\Users\agung\AppData\Roaming\VitySoft\FRD
Sat Apr 21 13:23:26 ICT 2018 WARNING: Couldn't create fir C:\Users\agung\AppData\Roaming\VitySoft\FRD
Sat Apr 21 13:23:56 ICT 2018 WARNING: Couldn't create fir C:\Users\agung\AppData\Roaming\VitySoft\FRD
is it because 64-bit Firefox
The 64-bit version of Firefox does not support NPAPI plug-ins, including Java.?
Edited 2 time(s). Last edit at 04/21/2018 06:34AM by majin_buu88.
April 21, 2018 11:26PM
if "SlimerJS not found" still appears you installed SlimerJS wrong
try again
most likely SlimerJS was put in the wrong FRD folder
September 05, 2018 06:36PM
Please show me where is the FRD folder -- Thank you in advance
Re: SlimerJS not found and Failed to parse slim js error msgs
January 06, 2019 09:09PM
Freerapid .094U and latest plugin.
1. I down load Slimer js 1.0 and put in directory FRD. Still have the error msg.
2. The new error msg I got --Failed to parse Slim Js (2) --
Any one have any ideas to fix those. I am using @#$%& and this tool did not have any error.
Thank you in advance.
March 24, 2019 10:21PM
I just used the SlimerJS tool with ulozto.cz - for each download, two windows opened - one small with an image containing word "SlimerJS",
and one bigger, which was empty with only "Submit" button, which did nothing.
When I closed all these windows, FRD showed java lang exception errors for all these downloads... really a mess.
Are ulozto.cz, some FRD plugin, or SlimerJS incompatible now?
Edited 2 time(s). Last edit at 03/24/2019 10:33PM by ifox.
May 05, 2019 04:14AM
Follow tong2shot's instructions and download the pre-configured setup to get SlimerJS working correctly
> Is it possible upload somewhere a configured
> version ?
Sure, here is download link for SlimerJS+FirefoxPortable60ESR, tested on Windows 10 64bit: [uptobox.com]
Anyone can create & fix plugins
December 20, 2019 02:20PM
> 10 64bit:
"File not found
Unfortunately, the file you want is not available."
Edited 1 time(s). Last edit at 12/20/2019 02:21PM by ifox.
January 09, 2020 02:02AM
ifox Wrote:
> "File not found
> available."
See newer downloadlinks for pre-configured archive "SlimerJS_FirefoxPortable60ESR.7z" uploaded again
Join 9kw.eu Captcha Service now and let your software continue downloads while you sleep. :)
