I have upgraded my JRE from Java Runtime 8 (Oracle) to Java Runtime 11 (OpenJDK).
And after that, FreeRapid Downlader is not working correctly.
(Fatal Error - java.lang.Error: java.lang.reflect.InvocationTargetException)
This happened after pasting URL from clipboard to the dialog.
Can you fix the error and in best case make FreeRapid compatible with borh JRE 8 and JRE 11?
My Java version is OpenJDK Runtime Environment AdoptOpenJDK (build 11.0.4+11) 64-bit
I am running Windows 10 (1903) 64-bit (czech).
I have the latest Freerapid 0.9u4.
