java.lang.UnsupportedOperationException: The system tray is not supported on the current platform. December 17, 2020 02:46PM |
Error Message: java.lang.UnsupportedOperationException: The system tray is not supported on the current platform. Level: SEVERE Stack Trace: The system tray is not supported on the current platform. java.awt.SystemTray.getSystemTray(SystemTray.java:186) sun.awt.X11.XTrayIconPeer$4$1.run(XTrayIconPeer.java:225) java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311) java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) java.awt.EventQueue.access$500(EventQueue.java:97) java.awt.EventQueue$3.run(EventQueue.java:709) java.awt.EventQueue$3.run(EventQueue.java:703) java.security.AccessController.doPrivileged(Native Method) java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84) java.awt.EventQueue$4.run(EventQueue.java:733) java.awt.EventQueue$4.run(EventQueue.java:731) java.security.AccessController.doPrivileged(Native Method) java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) java.awt.EventQueue.dispatchEvent(EventQueue.java:730) java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109) java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190) java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235) java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233) java.security.AccessController.doPrivileged(Native Method) java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233) java.awt.Dialog.show(Dialog.java:1084) java.awt.Component.show(Component.java:1671) java.awt.Component.setVisible(Component.java:1623) java.awt.Window.setVisible(Window.java:1014) java.awt.Dialog.setVisible(Dialog.java:1005) org.jdesktop.swingx.JXErrorPane$1.run(JXErrorPane.java:398) org.jdesktop.swingx.JXErrorPane.showDialog(JXErrorPane.java:411) cz.vity.freerapid.swing.Swinger.showErrorDialog(Swinger.java:297) cz.vity.freerapid.swing.Swinger.showErrorDialog(Swinger.java:286) cz.vity.freerapid.swing.Swinger.showErrorDialog(Swinger.java:260) cz.vity.freerapid.swing.Swinger.showErrorDialog(Swinger.java:268) cz.vity.freerapid.core.application.GlobalEDTExceptionHandler$1.run(GlobalEDTExceptionHandler.java:89) java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311) java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) java.awt.EventQueue.access$500(EventQueue.java:97) java.awt.EventQueue$3.run(EventQueue.java:709) java.awt.EventQueue$3.run(EventQueue.java:703) java.security.AccessController.doPrivileged(Native Method) java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) java.awt.EventQueue.dispatchEvent(EventQueue.java:728) java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Re: java.lang.UnsupportedOperationException: The system tray is not supported on the current platform. December 17, 2020 02:53PM |
Admin Registered: 17 years ago Posts: 2,424 |
Re: java.lang.UnsupportedOperationException: The system tray is not supported on the current platform. December 17, 2020 08:12PM |
Re: java.lang.UnsupportedOperationException: The system tray is not supported on the current platform. December 17, 2020 08:21PM |
Re: java.lang.UnsupportedOperationException: The system tray is not supported on the current platform. December 22, 2020 09:34AM |
Re: java.lang.UnsupportedOperationException: The system tray is not supported on the current platform. December 22, 2020 10:29AM |
