[Solved] Display setting not saved
Posted by mike69290
November 17, 2021 12:29PM
Hello
Freerapid cannot memorize my display setting. I mean place & size of the columns in the main list. After each restart, the display comes back to default. angry smiley
How to save my preferences?
I use the last update on Windows10.
Edited 2 time(s). Last edit at 11/29/2021 05:38PM by mike69290.
Re: Display setting not saved
November 29, 2021 05:37PM
Got it! FRD is always running on backround and launched at windows startup. So it is always closed with the computer shut down.
But to save its settings, FRD must be closed properly and not by the global shut down.
