login problem
Posted by nikos
login problem
October 12, 2009 07:04PM
I have the following problem
I used freerapid downloader with premium rapidshare for one month (with one month subscription)
Before the month expires I renew the subscription but after that I cannot download because each time a pop up window comes in the front and asks for user name and password of the premium-rapidshare account.
Although I enter the required info after a while the pop up windows comes on again and again
What shall I do to fix that?
Re: login problem
October 12, 2009 07:08PM
Aren't your credentials still inactive/invalid?
You can try to delete this file:
c:\Documents and Settings\YOUR_USER_NAME\application data\VitySoft\FRD\plugin_RapidSharePremium.xml
Otherwise the credentials are invalid.
Edited 1 time(s). Last edit at 10/12/2009 07:09PM by Vity.
